To Zone Or Not To Zone? Need Your Opinion! - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-11-2012, 08:23 PM   #16
I'm Your Huckleberry
Rewards Points: 2,270
To Zone or Not to Zone? Need Your Opinion!
Originally Posted by DCTepper View Post
Sorry, I should have mentioned that there are currently NO runs in the basement, only the preliminary batting insulation on the walls. I agree, the 6F difference will become closer to 3-4F at most once the ducts are run and the R13 is installed against the exterior walls.
As far as the mini system, I am not concerned with cooling as much as I am heating in the winter.
And the plot thickens...
So was or was not the basement included in the original heat load analysis? If not than you may find your current 60k btu system will struggle a bit conditioning the entire structure.
Those mini splits come in heat pumps as well meaning both heating and cooling all by way of self contained (paid for only once!) refrigerant so you will not be paying for gas or electric (beyond the normal condenser/heat pump and blower being on).
Just something to think about.
I understand what youre' saying BT and it makes sense, but still wondering what the original heat load entailed.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-11-2012, 09:09 PM   #17
Missouri Bound's Avatar
We pretty much live in our lower level. It's 1400 sq. ft. and it is always cooler there than in the main level.. Large living room, laundry room, bedroom, bathroom and library. Because of power failure due to ice storms I installed a generator and a small 24,000 btu fireplace, ventless. The room in the winter can get as low as 63-64 degrees before the fireplace. Now in 30 minutes it is 72 + to any temperature we want. Ceiling fans circulate the heat, and in 1-2 hours the heat travels up the stairway and the main level furnace gets a break....sometimes for 3-4 hours. I'm all for supplemental heat and cool, but I didn't want the eyesore of another condensing unit for a split system. (yes I said eyesore)
Supplemental heat can be in any form, baseboard heat, radiant heat, even portable heaters. I'd leave the original heater alone, assuming it is in good condition and add something for the lower level....will you need cooling there?
Do you want it your way or the right way?
Old 05-12-2012, 02:27 AM   #18
Thread killer
Rewards Points: 272
I see your concern, Doc, but most heat loss calcs have a bit of fluff in them plus design day doesn't usually last very long. With the added insulation, he should be ok, imo.
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
3rd zone not working properly MichaelChlopik HVAC 1 10-15-2010 06:59 PM
Boiler one zone call heat but not fire up Ballastar Plumbing 6 02-13-2010 12:17 AM
Adding new zone makapacs HVAC 0 11-26-2009 01:35 PM
need some help sorting out my new heating zone please wombosi Plumbing 3 04-23-2009 05:54 PM
help with third heat zone i just put in... wombosi HVAC 6 04-21-2009 01:02 PM
