Zone Dampers - Install On Both Supply And Return? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-01-2011, 01:43 AM   #1
Rewards Points: 150
Zone Dampers - Install on Both Supply and return?
Planning out zones for my central air system, I'd like to have 3 " zones "
Zone 1 - Main level in my ranch home, including all bedrooms
Zone 2- Finished Basement
Zone 3 - Three Season type of porch/sunroom
Planning on using automatic zone dampers such as:
http://www.climatedoctors.com/items/...?itemid=846907
Will it be necessary for all zones to have zone dampers on both supply AND returns? I figure i'd need to cut off the return and supply on the porch so im not sucking in all that hot air into my system.
but should i need one one the basement return as well? would i benifit by having the return always open on the basement to suck out humidity / moisture?
alecmcmahon is offline   Reply With Quote
Old 05-01-2011, 04:25 AM   #2
An old Tradesmen
Rewards Points: 7,278
No need for dampers on any of the returns. The returns in the porch area won't draw air in when its not calling, unless your short on return for the other areas.
Old 05-01-2011, 04:27 AM   #3
Rewards Points: 150
Even if all 3 'zones' are off a single air handler?
Old 05-01-2011, 04:33 AM   #4
An old Tradesmen
Yep. The returns shouldn't draw air in, unless that area is the one being supplied with air. If they do draw air in when that area isn't calling for heat or cooling, then its a sign that your return system is under sized. Which means you don't want to close that return anyways then. Since its giving the return volume your system needs.
Distance between HVAC supply and return vents atlantatd HVAC 4 04-13-2011 08:30 PM
Cold Air Return next to supply duct thebigbbm HVAC 6 09-21-2010 05:51 PM
need some help sorting out my new heating zone please wombosi Plumbing 3 04-23-2009 04:54 PM
help with third heat zone i just put in... wombosi HVAC 6 04-21-2009 12:02 PM
Supply and Return Issue billybob45 HVAC 4 07-31-2008 09:44 PM
