Zone Control A/c - HVAC - DIY Chatroom Home Improvement Forum
Old 08-15-2012, 11:21 PM   #1
zone control a/c
have a 2 story house with zone control. Downstairs cools a few degrees past what thermostat is set on while the upstairs cools about 10 degrees colder than set. This mainly occurs overnight. What might be the issue?
waadams1 is offline   Reply With Quote
Old 08-15-2012, 11:46 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Where are these thermostats located in respect to their return air grills?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 08-16-2012, 04:54 AM   #3
An old Tradesmen
Rewards Points: 7,826
Zone dampers may be sticking partially open, or not closing at all. Also the dampers may be set to a min open position duct to under sized duct work. Check to se if your dampers are closing, and if they are set to a min open position.
Dual zone damper control question Mountie0329 HVAC 0 06-07-2011 08:49 AM
Manual dampers vs. motorized w/smart sensors and zone control... charljlee HVAC 0 06-27-2010 12:05 PM
multi zone control home heating - ? SixStrRzr HVAC 7 02-15-2010 03:58 PM
carrier furnace and honeywell zone control issue bmccarron HVAC 14 09-20-2009 09:59 AM
HVAC very weak upstairs with zone control installed g8rben HVAC 5 06-14-2009 06:51 PM
