Old 12-14-2007, 02:26 AM   #1
Zone 1 not working properly
I have a two zone system. All of a sudden, both zones, whether they are on simultaneously or independently, are only heating the upstairs. Nothing is blowing downstairs. This is a Carrier system. Any help is appreciated.
thx
doug galloway is offline   Reply With Quote
Old 12-14-2007, 09:31 AM   #2
Sounds like a zone control module problem. If it was fan/dampers, you'd have nothing blowing anywhere with only downstairs thermostat calling for heat.
scorrpio is offline   Reply With Quote
Old 12-14-2007, 05:10 PM   #3
Post
Scorpio, thanks for the reply. Is it possible that the damper is stuck in a position that is only allowing the air to flow upstairs only?
Old 12-14-2007, 06:18 PM   #4
yes.
You may be able to manually open the ones that you need or vise versa.
redline is offline   Reply With Quote
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
Adding another HVAC Zone handy man88 HVAC 3 10-09-2007 10:45 PM
Wiring of my two-zone system not working correctly AMontemagni HVAC 3 01-27-2007 01:07 PM
Zone system not working with heat. deliriousga HVAC 5 12-29-2006 07:04 PM
