Zenith Air Conditioner - HVAC - DIY Chatroom Home Improvement Forum
Old 06-26-2010, 06:42 PM   #1
I purchased a Zenith zw5000 air conditioner. I can't find the amps that it uses anywhere. Anyone know where to find that info?
Second, the manual says I will need a dedicated circuit. My house is older and I don't have a circuit that can be dedicated. When I was in college we just plugged it in and didn't think twice. Do I really need a dedicated circuit, or can it be on a circuit with low draw items like lights.
Thanks,
Chris
**Edit** The customer service line just confirmed that the air conditioner is a 4.8amp draw. Is there any reason that it couldn't go safely on a 15 or 20 amp circuit with little else but incandescent lighting on the circuit. Thanks
chrisatola is offline   Reply With Quote
Old 06-26-2010, 07:19 PM   #2
AC can use more on startup
But I have used a 12,000 BTU AC on a shared circuit without a problem
The 4.8a rating is a fairly low draw, shouldn't be a problem
Old 06-26-2010, 07:49 PM   #3
thanks
Old 06-26-2010, 09:27 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,818
Probably they are worried about frivolous lawsuits if the voltage drops when the unit starts and someones computer takes a dump. They overspec products and details to protect themselves.
Old 06-27-2010, 06:44 AM   #5
An old Tradesmen
Rewards Points: 6,876
I think they spec all window units to be on their own circuit.
Just as a precaution as Yuri said.
Old 06-29-2010, 08:07 AM   #6
Thanks for the help guys! It appears to be working fine on the shared circuit.
Heat pump vs. Furnace and Air Conditioner heating&cooling HVAC 11 06-16-2010 06:07 PM
air conditioner tripping at current interrupter donny.frankrice HVAC 10 07-07-2009 02:08 PM
Novel Way to increase effeciency of portable Air conditioner Tell me what you think macmini HVAC 5 05-25-2009 05:58 AM
Installing window air conditioner mary60 Electrical 1 08-14-2008 06:25 PM
window unit air conditioner help? greenvorlon Appliances 1 08-03-2007 11:50 AM
