You Guys Helped Me Last Year Now I Need Your Help Again... - HVAC - DIY Chatroom Home Improvement Forum
Old 05-10-2010, 08:14 AM   #1
You guys helped me last year now I need your help again...
Morning All,
You helped me out last year with my AC service. Saved me from getting ripped off. Thanks!
http://www.diychatroom.com/f17/hvac-just-serviced-thoughts-needed-repairs-45144/index4/
Now I could use your advice again. All caps were replaced last year and last night I noticed a loud humming coming from the furnace. At first I thought it was the blower motor but that was not it. I had my wife switch on the blower and started/stopped fine. I quickly heard/felt the him from the transformer. The air conditioning wouldn't turn on when I set the temp down. I turned on the furnace everything kicked in and turned it back to AC and it then kicked on.
Sound like a bad transformer? or something else?
ashton is offline   Reply With Quote
Old 05-10-2010, 04:53 PM   #2
An old Tradesmen
Rewards Points: 6,548
Could be a stuck contactor in the outdoor unit.
Old 05-10-2010, 06:53 PM   #3
The points look bad on the contactor. The numbers are all washed out and I want to order the correct one. Can you guys help tell me where and which one to get?
You guys helped me last year now I need your help again...-5-10-2010-005.jpg   You guys helped me last year now I need your help again...-5-10-2010-002.jpg
Old 05-10-2010, 07:07 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,442
They are rated in amperage draw for the contacts at 240 volts. Kinda looks like yours is a 25 amp model. I would order a 30 amp 24 volt contactor from Grainger. Slightly stronger contacts are better anyway. Double pole single throw type. Be careful as you need one with a joined set of contacts/buss bar type. Best to take the picture with you and drive down there.
Old 05-10-2010, 07:20 PM   #5
I was guessing it was a 25 single/shunt but will get what you suggest.
Thanks for all of your help!!!!
You guys are the best!
Old 05-15-2010, 04:26 PM   #6
update...just received my contactors today and installed them.....A/c units working great!
I put on 30 amp. I am surprised both of my units lasted this long. I couldn't see any points on the old contactors....
Again...you all saved me a ton of money
If we dont say it enough...Thank YOU!
peeling year after year handifoot Painting 5 03-25-2010 07:45 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
What do you guys do to save on your Electricity bill? (2009 Edition) ehoez Electrical 47 04-10-2009 07:53 AM
Reroofing over Ten year old 3 tabbers gillaroo Roofing/Siding 15 05-02-2006 12:41 AM
