York Vs Coleman A-coil - HVAC - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 08:34 PM   #1
York vs Coleman A-coil
Is the York MC36C3XH1 and the Coleman MC36C3XH1 the same unit? Are the specs the same? Looking at the Coleman unit with a york 3 ton heat pump. Thanks for the help in advance!
Snipeston is offline   Reply With Quote
Old 05-28-2012, 08:58 PM   #2
Rewards Points: 616
as far as I know they are twins.... same plant..
carmon is offline   Reply With Quote
Old 05-29-2012, 03:15 AM   #3
An old Tradesmen
Rewards Points: 6,906
Yep, they're the same coil.
How To Select the Correct Coil ob2s HVAC 24 05-23-2012 12:46 AM
Evaporator Coil Sizing kandykane19 HVAC 0 05-05-2010 03:44 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 09:27 AM
Air conditioning coil heat tolerance? Badfish740 HVAC 1 10-19-2009 05:39 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
