Old 06-17-2010, 01:14 PM   #1
york unit condensor
york unit condensor will not kick on by temp setting,? will run when contactors are pushed in by hand. what is wrong or could be?
marko1121 is offline   Reply With Quote
Old 06-17-2010, 08:32 PM   #2
biggles's Avatar
york unit condensor
remove the stat off the subbase jump R to Y1 let somebody be out the window to tell you if it comes on then remove the jump..paper clip short piece of thin wire..just hold it there ...if it bumps on the stat in hand isn't making contact...take an pencil eraser clean all the contacts on the base and stat..see if fan runs in ON when switched....before cleaning to see if that is making contact...will check back..
York AC unit running slow...Please help :^( mr.coinring HVAC 52 05-29-2010 05:41 AM
Armstrong unit vs York unit Nayr HVAC 5 02-04-2010 01:54 PM
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 32 04-15-2009 11:46 PM
York Affinity 8T YZE03611C unit Pennsydave HVAC 10 03-23-2009 09:09 PM
York AC unit outside not turning on ssssg1 HVAC 1 07-25-2006 09:30 PM
