York Or Trane? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-26-2010, 12:24 AM   #1
koz
York or Trane?
I've got two quotes, one for a 3-ton Trane xl16i. and another for a York 3-ton 8T HP.
They're basically the same on specs (below), the York is quieter and about $1000 cheaper.
Right now I'm leaning towards the cheaper quieter York.
Any recommendations?
The specs:
Both are 18 SEER.
The Trane is HSPF 9.2
The York is HSPF 9.4
As far as I can tell the Trane is 74db the York is 65db.
Both have two stage compressors.
The Trane: http://www.trane.com/Residential/Pro...16i-Heat-Pumps
The York: http://www.yorkupg.com/homeowners/co...p?fldProdID=20
koz is offline   Reply With Quote
Old 05-26-2010, 05:42 AM   #2
An old Tradesmen
Rewards Points: 6,906
The York has better humidity control then the Trane.
But, since its so cheap. I'd shy away from that dealer. Since that would be the top of the line for York. And the Trane 16i is a second teir unit.
Makes you wonder what corners the York dealer is cutting.
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 02:32 PM
Need some friendly advice-- Coleman/York v. Trane biggerdaddynj HVAC 3 05-09-2010 10:46 AM
Help me compare Trane heat pumps pls tomseeley HVAC 3 04-02-2010 05:54 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 12:59 PM
Humid - Switched Trane xl1200 AC for a Payne HP - now very Humid dagrappler HVAC 1 06-11-2007 12:16 PM
