York Rooftop Furnace Will Not Ignite - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 06:02 PM   #1
york rooftop furnace will not ignite
i have 1997 york rooftop furnace that was only used for the ac. i wanted to get it running to use as a back up. it worked breifly....then quit. the inducer comes on and the fan blower runs. i was told to replace the board....but still the same. told to replace the gas valve..but still the same. gas valve is honeywell sv9501. now i have been told that the gas line is probably too small. it is a 1/2 inch line that comes out of a 3/4 inch line that also runs another furnace. the 1/2 inch line is about 25 feet long. any ideas?
transanlt1 is offline   Reply With Quote
Old 01-02-2012, 06:03 PM   #2
Rewards Points: 12,818
Stop guessing and call a real service person.
Old 01-02-2012, 06:34 PM   #3
biggles's Avatar
might of cooked the glow coil or the spark ignition isn't that clean causing a low sparking...do you hear the spark ignition sparking strong like a stove top sparker remove the pilot assembly and brush it and sandpaper the probe lightly
Old 01-02-2012, 08:18 PM   #4
Rewards Points: 582
I think thats hot surface ignitor...is it glowing... or is it clicking... seems like the pressure switch may be causing you a problem...did you check that..
Old 01-02-2012, 09:05 PM   #5
the hot surface igniter does not glow and there is no clicking. there is no gas going to the pilot. the pressure switch appears to be working. is it possible to shunt the switch?
Old 01-02-2012, 10:03 PM   #6
Rewards Points: 582
post us some pictures... of what your looking at to hard to tell without seeing.....
Old 01-02-2012, 10:14 PM   #7
REP
Do you have voltage anywhre in the low voltage circut?Did you check the gas pressure with and without the other furnace running?
Have you olmed out the limits to see if they are closed?
If you are going to continue to repalce parts until it starts working go for a transfomer and pressure switch next.
Oh and is the gas cock open?Did you purge the gas line of air?
Oh yea another thing.If its a white Rogers ignition is the pilot sensor working.That would be the 3 or 4 prong thing that plugs into the gas valve.Again if its White Rogers you might want to check that the mounting screws holding the spark box on is touching clean bare metal and its tight.This is because the rectification signal comes from the unit ground back into the spark box.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
ben's plumbing (01-02-2012)
York Stellar Furnace - help me find my ignitor pmandra HVAC 3 02-17-2012 08:50 AM
York Diamond 90 furnace not starting items HVAC 14 12-23-2011 11:57 AM
furnace will not ignite lisa e HVAC 2 12-03-2009 07:15 PM
Old York combo Furnace - Customize?? fedupGC HVAC 5 10-28-2009 07:32 PM
Slant/Fin gas furnace won't ignite... Switchvert HVAC 14 01-11-2009 11:04 PM
