York High Efficiency Heat Exchanger Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 12-18-2008, 12:38 PM   #1
York High Efficiency Heat Exchanger issue
I am having a problem with my York Tubular Heath Exchanger, not sure of the exact model# but the manual shows model#s PS8/FC8s/FL8s/LC8S/LL8S. We keep the temperature set low while we are sleeping and while at work. When the sytem kicks on to start warming the house the system will come on but the fan is not blowing. We restart and then it works fine until the next morning. We had someone come out last year for the same thing and they said everything was fine it might have been a short from having the christmas lights on. This is the only time of year that this happens. What do you think? FYI it has been exceptionaly cold -15 one day and the 10 the next.
aduraes is offline   Reply With Quote
Old 12-18-2008, 09:01 PM   #2
An old Tradesmen
Rewards Points: 6,548
If it only happens when you are using youor christmas tree lights.
Its probably a problem with the neutral wire.
Is the furnace on its own circuit. Or, is the recep that the lights plug into, on the furnace circuit.
Heat Exchanger?? sunsetacres1318 HVAC 6 02-26-2009 11:15 AM
Cracked heat Exchanger darman16 HVAC 4 10-27-2008 10:11 AM
venting a high efficiency furnace through the roof (how high) allAboutDIY HVAC 11 10-21-2008 01:48 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
Adding Geothermal heat exchanger to window unit richinok HVAC 4 06-23-2008 07:59 PM
