Old 06-10-2012, 10:20 PM   #1
York Heat Pump and A-Coil
I am looking at a York YJHF 3 ton heat pump and have been told that I need to upsize the coil to maximize efficiency. Would the York G2FD046H17A 4 ton a coil work with the heat pump I am getting? I need a horizontal application coil.
Snipeston is offline   Reply With Quote
Old 06-10-2012, 10:53 PM   #2
An old Tradesmen
The g2FD coils are obsolete. And there is no listing for the YHJF36S41S1 matching to the G2FD046H17A coil. So you may get more or less efficiency with that match up.
The FC/MC43B gives a good match up. 24,200 BTUs of heat at 17 degree outdoor temp at a COP of 2.55
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 08:48 PM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 06:38 AM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
VisionPRO Setup Functions & Heat Pump infoskr HVAC 31 03-18-2010 02:15 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
