#1 |
York Heat Pump
I checked the contactor and it was pulled in so I turned the fan by hand then it started but the compresor didn't start any ideas
I have a york heat pump the outdoor unit quit working I checked the contactor was pulled in.The fan motor and the compressor were not running. I turned the fan motor by hand and it started but the compressor wouldn't run any Ideas Thanks Paul |
#2 | |
York Heat PumpQuote:
You should hear the compressor hum slightly for about 1.5 to 2 seconds then kick out on overload since it is trying to start but can't if the capacitor is bad. They both use capacitors but it may be a dual capacitor that does both fan and comp. This is very common. It will be silver metal and about 2 inches diameter and about 4-6 inches tall. If it is a dual run cap, it will have three terminals on the top marked Herm, C, and Fan. Get the rating off of it and get a new one. I just replaced a 45uf(MFD) / 5uf 370v one last night. They are less tha 30 bucks. You could also have two separate caps....they will be 2 terminal ones. You could also have a black plastic start one for the comp. Let me know what you find in there. |
| Display Modes | |
| New Install - Heat Pump Woes... | mark1210 | HVAC | 7 | 03-07-2010 10:14 AM |
| Comparison and Heat Pump Selection help... | ChrisDIY | HVAC | 7 | 03-06-2010 09:34 PM |
| New Heat Pump..questions? | ddave23 | HVAC | 4 | 03-05-2010 06:13 AM |
| Getting a House..heatpump or no? | DavidsCPU | HVAC | 10 | 02-07-2010 11:22 PM |
| changed thermostat on York Affinity, now no heat? | sotwell | HVAC | 1 | 03-01-2009 06:34 PM |
