YORK Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 01-01-2012, 01:52 PM   #1
YORK heat pump
We moved to a house with a York heat pump (built in 2001)... The unit has recently developed a frost ring about 4" inches high around the middle of the coils... Anyone know what causes this and how it can be fixed?.. Thanks... WilySam
Wilysam is offline   Reply With Quote
Old 01-01-2012, 02:07 PM   #2
This is a normal occurrence, if you watch it long enough you will see the unit go into a defrost cycle. Now if it turns into a giant ice cube, then you have issues.
harleyrider is offline   Reply With Quote
Tags
frost , heat pump , york
York Heat Pump - AC blows hot air on cold nights Tpayneful HVAC 0 06-08-2011 08:46 AM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 06:38 AM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 10:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
New Heat Pump..questions? ddave23 HVAC 4 03-05-2010 06:13 AM
