Old 03-21-2007, 09:12 AM   #1
York gas heater control board replacement
I am having trouble with a York diamond 90 gas heater. The unit blows cold air every few days. Once the power is cycled on the unit, it works and blows hot air. A HVAC company came out and stated that the fault lights is flashing 8 times and needs a new control board. The price is about $500 installed.
I found the part online York #33101972200 for $125.
How difficult is the control board replacement? It looks like a direct swap to me.
spyvan is offline   Reply With Quote
Old 03-21-2007, 10:00 AM   #2
Can you post a picture of the board?
harleyrider is offline   Reply With Quote
Old 03-21-2007, 10:45 AM   #3
Old 03-21-2007, 10:51 AM   #4
Originally Posted by spyvan View Post
Not exactly the same, but the plugs are the same
Old 12-28-2008, 11:24 AM   #5
I have a bad control board as well. Service guy wants to charge $600.00. Where did you find your replacement board?
richertt is offline   Reply With Quote
Old 12-29-2008, 08:12 AM   #6
An old Tradesmen
Depending what year your furnace is.
Your board probably isn't bad.
May have a dirty flame sensor.
A bad pressure switch.
Cracked hose running to a pressure switch.
A restriction in the venting.
Usually, when the board is bad, it won't recycle and give you heat.
Look on the furnace panel, at what code 8 indicates.
Install of Replacement HW Heater DIY In King George Plumbing 19 01-12-2007 08:49 AM
Water Heater - replacement info. CJP Appliances 1 11-17-2006 04:14 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 10:33 PM
