-   -   York gas heater control board replacement (http://www.diychatroom.com/f17/york-gas-heater-control-board-replacement-7268/)
spyvan 03-21-2007 09:12 AM
I am having trouble with a York diamond 90 gas heater. The unit blows cold air every few days. Once the power is cycled on the unit, it works and blows hot air. A HVAC company came out and stated that the fault lights is flashing 8 times and needs a new control board. The price is about $500 installed.
I found the part online York #33101972200 for $125.
How difficult is the control board replacement? It looks like a direct swap to me.
harleyrider 03-21-2007 10:00 AM
Can you post a picture of the board?
spyvan 03-21-2007 10:45 AM
pic of replacement board
http://arnoldservice.com/33101972200...oard%20all.JPG
harleyrider 03-21-2007 10:51 AM
Originally Posted by spyvan (Post 37743)
http://img.photobucket.com/albums/v1...cture_0223.jpg
Not exactly the same, but the plugs are the same
richertt 12-28-2008 11:24 AM
I have a bad control board as well. Service guy wants to charge $600.00. Where did you find your replacement board?
beenthere 12-29-2008 08:12 AM
Depending what year your furnace is.
Your board probably isn't bad.
May have a dirty flame sensor.
A bad pressure switch.
Cracked hose running to a pressure switch.
A restriction in the venting.
Usually, when the board is bad, it won't recycle and give you heat.
Look on the furnace panel, at what code 8 indicates.
