York Gas Furnace 031-01972-000 - HVAC - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 08:47 AM   #1
My furnace isn't coming on. The green LED on the control board is flashing one time. Any suggestions on what the problem may be?
Does anyone have the diagnostics info for the control board?
IDIM is offline   Reply With Quote
Old 03-09-2013, 09:53 AM   #2
An old Tradesmen
Rewards Points: 8,202
Codes should be on the panel. Is it a heart beat. That would mean normal operation, no call for heat or cooling.
Old 03-09-2013, 12:07 PM   #3
Experienced HVAC Tech
HVAC1000's Avatar
being that every brand uses a different blink code and a different control board it would extremely help to post make and model.
HVAC1000 is offline   Reply With Quote
Old 03-09-2013, 12:24 PM   #4
An old Tradesmen
He said its a York.
Old 03-09-2013, 03:29 PM   #5
It is a York 40-130 MBH. The control board number is listed in the title. I found the installation instructions for it and they do indicate a single flashing green LED is the normal state. I will take a look now at the inputs from the thermostat. I also have a Ruud Steam Humidifier on the system that is flashing a code indicating HVAC power loss.
Old 03-09-2013, 04:36 PM   #6
An old Tradesmen
Disconnect the wires from R and W on teh control board, and run a jumper from one to the other, and see if it runs in heat mode then.
Old 03-10-2013, 08:41 PM   #7
Checked out the thermostat and the 24v transformer and they both looked fine. Tried turning the system back on and it fired right up. I'll have to keep an eye on it and see what happens. Thanks for the comments.
Old 03-10-2013, 08:50 PM   #8
Roofmaster
Rewards Points: 2,210
They looked fine? Did you put a multimeter on the transformer?
Tags
031-01972-000 , gas furnace , york
Gas Furnace Replacement Questions mark2741 HVAC 31 01-17-2013 12:15 AM
York furnace problems WHM08 HVAC 6 04-10-2011 07:41 PM
york upright oil furnace with direct drive blower motor bigbruce HVAC 10 10-16-2010 02:07 PM
York PM9 Mod Furnace, Aux Fan Question javan HVAC 20 02-10-2009 08:22 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
