York Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2013, 08:24 PM   #1
Handyman
brucem609's Avatar
Rewards Points: 79
York furnace problem
I will try and make this as concise as possible.
We have had a York furnace now for 2 1/2 years and have had difficulty almost from the beginning. The contractor has replaced, fan motor, gas valves, pressure switch (3x) main circuit board, replied the exhaust & intake and still have problems. Furnace not firing, trouble codes etc.
the current furnace is a modulating furnace with a variable speed blower. The model number is PM9C. After speaking with the guys at Johnson Controls I find out they have had problems with this furnace.
OK, here is the question. They are replacing the furnace, and they are replacing it with a 2 stage furnace with a variable speed blower. The model number is TM9V.
I have read mixed reviews on this model.
Any suggestions? Should I accept this furnace? Is it as good as the one I purchased? But doesn't work
I want a winter where I will not be cold this year!
Sent from my iPad using DIY Forum
brucem609 is offline   Reply With Quote
Old 11-01-2013, 08:40 PM   #2
raylo32's Avatar
Rewards Points: 1,226
I have an 80k btuh TM9v 2 stage ECM variable speed furnace just starting its 3rd winter and it has been mostly good. The only issue I have had is a minor leak from a seam on the condensate collector box that I fixed with a little epoxy. No issues whatsoever with pressure switches, circuit card, blower, inducers, etc. I got this to upgrade from an old single stage unit and really like the quieter first stage where it runs most of the time... and like the 2nd stage for quick heat ups from programmed setbacks at night and during the day when at work. So I am happy with it and would recommend it. As the pros here say a lot depends on the install and the company that services it.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 11-01-2013, 09:00 PM   #3
An old Tradesmen
Rewards Points: 6,142
The TM9V is 2 steps down from the Mod furnace you have.
What size is your current furnace. What size is your house?
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (11-03-2013)
Old 11-02-2013, 10:28 PM   #4
Rewards Points: 614
TM9V is one model under the modulating.... its still a York...Good luck... they are getting better
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
Old 11-03-2013, 06:31 AM   #5
An old Tradesmen
There's a 2 stage Affinity that would be between the TM9V and the mod.
Old 11-03-2013, 09:41 AM   #6
Rewards Points: 614
never heard of that one.... thanks for correcting my error.....
Old 11-03-2013, 07:21 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
The shop I worked for before I opened my shop back in 96 was a york dealer,I still have nightmares about those noisy ass compressors!
The supply house asked me if I wanted to be a york dealer a couple months later,I told them I was already set up for rhuud/rheem and goodman equipment.
ACU in omaha didnt want to talk to me much after that discussion.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 11-03-2013, 07:35 PM   #8
An old Tradesmen
The Bristol days.
plummen (11-03-2013)
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 09:18 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 01:01 AM
Strange Problem with My Furnace chenjijc HVAC 14 11-04-2009 10:05 PM
