York Furnace Flame Stays On Only 5 Seconds - HVAC - DIY Chatroom Home Improvement Forum
Old 01-18-2007, 09:32 PM   #1
Question
York Furnace flame stays on only 5 seconds
We have a York Diamond 80 model pidub12nob001a. The jets fire up for only 5 seconds and then turn off. The blower then runs. I have checked the filter and it is ok any suggestions?
Thank you!
PatJo is offline   Reply With Quote
Old 01-18-2007, 09:57 PM   #2
Seems to be working now
I powered it down for 15 minutes and dusted out the furnace. It seems to working now. ANy suggestions regarding what could have caused this? What I may need to have done to the furnace?
Thank you for your replies in advance!
Old 01-19-2007, 09:23 AM   #3
Send a message via ICQ to Furnace_dude Send a message via AIM to Furnace_dude
the problem is easy to fix and will occur again. however, what needs to be done is not clear to me as i am not in front of the furnace. it could range from a simple cleaning to an expansive repair of several hundred dollars.
Furnace_dude is offline   Reply With Quote
Old 01-19-2007, 10:18 AM   #4
Thoroughbred Mopar Man
Rewards Points: 502
Hi PatJo
It sounds like the problem you originally had was a dirty flame sensor or a burner was not igniting and causing lockout. I would definately reccomend having the furnace serviced, especially if it has been several years since it was serviced.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 01-19-2007, 10:25 AM   #5
Originally Posted by #CARRIERMAN View Post
Hi PatJo
It sound like the problem you originally had was a dirty flame sensor or a burner was not igniting and causing lockout. I would definately reccomend having the furnace serviced, especially if it has been several years since it was serviced.
Good luck
Rusty
dusting the furnace would not really 'clean' the flame sensor unless patjo actually cleaned it, but that would appear to be the problem, unless the sensor and or lead is bad, the ground may be getting weak and or the IFC going out, hard to tell
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
Whirlpool Furnace - Burners cycle every 10 to 20 Seconds agtsrbt HVAC 3 02-06-2007 05:39 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
weatherking furnace blower runs continuously rayborj HVAC 4 12-08-2006 03:23 PM
