York Diamond80 'C' Terminal - HVAC - DIY Chatroom Home Improvement Forum
Old 01-18-2012, 02:41 PM   #1
York Diamond80 'C' terminal
Hello,
I need a 'C' (24V) wire for my new t-stat. Currently, only 4 wires are coming into my old t-stat (W, R, Y, G). Since the conduit has at least two more unused wires, I suppose it shouldn't be a problem to use one of them to bring the 24V in from the York.
When I look at the York's terminals I see the 'C' terminal with no wires attached. How can I verify I am getting 24V on it? Basically, where do I apply voltmeter probes?
Thank you!
dimka2000 is offline   Reply With Quote
Old 01-18-2012, 02:50 PM   #2
Originally Posted by dimka2000 View Post
Hello,
Thank you!
C on the furnace is a neutral or return. R is hot or 24volts.
Connect one of the unused leads to the furnace C and the other end of the lead to C on the stat. Make sure furnace is OFF!!!!!
hvac5646 is offline   Reply With Quote
Old 01-18-2012, 02:55 PM   #3
Wow, that's a fast reply! Thanks a bunch!
So, to clarify, if I measure between C and R terminals, I should get 24V at all times, right?
Old 01-18-2012, 02:57 PM   #4
yep.
$750.. please
Old 01-18-2012, 04:56 PM   #5
yep.
$750.. please
ah-ha, so the membership is free, but the payments are per case?
btw, I got nothing when trying to measure between C and R, with or without panel switch depressed..... what am I doing wrong?
Old 01-18-2012, 05:13 PM   #6
raylo32's Avatar
Rewards Points: 1,254
Make sure your meter is set to AC volts, not DC!
raylo32 is offline   Reply With Quote
Old 01-18-2012, 06:08 PM   #7
D-ohhhh
Old 01-20-2012, 05:34 PM   #8
thanks Raylo32! that's what it was!
Old 01-20-2012, 05:34 PM   #9
D-ohhhh
dohhh indeed thanks for the help!
Compressor terminal post wiring connector came apart - remnant still sticking to post justplumducky HVAC 11 07-06-2011 08:04 PM
Heat but no A/C with new thermostat myqhenry HVAC 15 05-30-2011 10:53 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
York or Trane? koz HVAC 1 05-26-2010 05:42 AM
"G" terminal on Tstats javan HVAC 8 02-08-2009 02:16 PM
