York Diamond 90 Issues - HVAC - DIY Chatroom Home Improvement Forum
Old 03-09-2008, 08:21 AM   #1
I have a York Diamond 90 Furnace and the burner would stop after few minutes with LED blinking 6 times. If I turn off the heater and turn it ON again the burner will start but will shut off after few minutes and the blower keeps blowing cold air. Can anyone suggest what can I check.
Thank you,
SToronto is offline   Reply With Quote
Old 03-09-2008, 08:35 PM   #2
Talking
6flashes means it's time to replace the furnace! Just kidding!
Actually, if you look on the inside of your furnace panel you should see a diagnostic chart that will translate the code. Then post again telling us what the code means.
sgthvac is offline   Reply With Quote
York gas heater control board replacement spyvan HVAC 5 12-29-2008 07:12 AM
York Ignitor Issues fxman HVAC 7 01-31-2008 05:39 PM
York Diamond 90 heater Rob P198 HVAC 1 01-26-2008 08:11 PM
