York Diamond 80 Not Igniting and no heat
I live in FL and I have a dual set of York Diamond 80 air handlers in the ceiling of my garage. They have a gas furnace and separate a/c condensers outside.
I was not getting any power to the thermostat. I removed the thermostat and wired it directly onto the circuit board on the unit.
Now I have power to the thermostat. When I have the fan on auto and the heat on the flame flashes, but heat does not come on, no ignition of the gas, and no heating up of the ignitor.
My problem is that I have no heat.
The LED does not flash.
When I turn on the thermostat on and turn the heat on, turn the temp up, the down draft fan behind the circuit board turns on full, but the ignitor does not heat up, gas does not turn on or ignite, and the main fan does not come on.
I have powered down the full unit. No change
I have reset the all of the trip switches (2 in the down draft side) and three in the heat side.
I tested the capacitor by jumping it and it made no difference.
I have taken the panels off both units and compared to make sure a wire is not off.
Any help would be appreciated.
