York Diamond 80 New Never Installed, Burners Won't Stay Lit - HVAC - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 12:26 AM   #1
york diamond 80 new never installed, burners won't stay lit
I just installed this unit after having it for several years. It is a downflow model. Normal cycle begins, but after burners light they shut off. I cleaned and even changed the flame sensor from another unit but with no luck. I tried jumping all the sensors, nothing changed. I am getting the 7 flash error code that is the failure to ignite. I am not a professional just have some experience with my rental homes. I bought this unit at a frieght salvage sale. It had a few dings, but nothing major. I have installed several of these and this is the first I have had problem with. The gas line is new from the meter. I have read in other places including the manual that I could be getting low gas pressure????? could there be a problem with the meter or line? I hooked up only the red white wire to the thermostat, could this be an issue? any help with be greatly appreciated!
bsmith23 is offline   Reply With Quote
Old 12-21-2011, 04:25 AM   #2
An old Tradesmen
Rewards Points: 7,332
ow gas pressure could be the problem. But it could also be a bad ground to the furnace.
Old 12-21-2011, 08:58 AM   #3
Is the unit properly grounded? if so then you have a bad ignition board.
Sorry beenthere........dident see your post before i posted.
harleyrider is offline   Reply With Quote
Old 12-21-2011, 12:50 PM   #4
An old Tradesmen
No problem.
Old 12-21-2011, 09:47 PM   #5
thanks guys!
I checked for bad ground this morning after your suggestions. I was thinking I might find that the green wire was not hooked up, which I would have been surprised that made any difference since it is just a reduntant neutral anyway. When I opened up the connection box I realized that my helper was the one who hooked up the wiring and we used a power cord to plug it in instead of hard wiring it. So when I noticed this it hit me, he didn't trace the hot and neutral leads from the outlet to the furnace, because I tried switching them and it fired right up! I knew that I had read if this happened the unit would be shut down, but I assumed it wouldn't make it this far down the start up sequence. Thanks for your help, saved me a service call!
Old 12-21-2011, 09:58 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
I was just explaining that to a kid at school tonight about newer units with boards in them being polarity sensitive!
plummen is offline   Reply With Quote
York Diamond 80 Furnace won't start bobjay HVAC 1 12-01-2011 05:30 PM
York Diamond 80- Error code flashes 7 times apclyps HVAC 7 01-04-2011 03:30 PM
Burners wont stay on mrjacksonc HVAC 1 11-04-2010 04:58 AM
Dayton Gas Furnace burners wont stay lit Marie1313 HVAC 38 10-08-2009 04:38 PM
Furnace burners flame out after a few seconds snurb HVAC 3 01-13-2009 07:58 AM
