York Diamond 80 Lockout - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 10:29 PM   #1
York Diamond 80 lockout
Hello,
I am having trouble with a York Diamond 80 at work. We have multiple units. The circuit board is flashing 7( lockout after 3 attempts and no ignition). The unit is doing just that. The inducer motor runs, the ignitor glows and gas is ignited. 5 seconds after ignition the gas trips off. This repeats 3 times and the system locks out.
What I have checked/done: Like I said we have multiple units. I have switched out the flame sensor, pressure switch, circuit board and thermostat with a different working unit. All parts have worked in the other unit and my result was the same(lockout). I have also jumped out every sensor and limit switch that I can see/reach with the same results. The filter is clean, the exhaust vent and air intake are unblocked and clean. I also cleaned the flame sensor with fine steel wool.
I did have momentary success when the pressure switch was jumped out, But I could not duplicate it. I'm just looking for anything I may have missed or not thought of.
fire2434 is offline   Reply With Quote
Old 11-08-2012, 11:41 PM   #2
Rewards Points: 616
pressure switch is not happy...look for plugged hoses or ports where pressure switch hooks to...
carmon is offline   Reply With Quote
Old 11-09-2012, 08:47 AM   #3
weinstall.ca
Furnace repair to york
I agree with the previous
Just had a furnace in Toronto with the same problem.
We just replaced the pressure switch hose, it was cracked.
allan is offline   Reply With Quote
Old 11-09-2012, 12:45 PM   #4
Thanks, Cleaned ports with a paperclip, inspected and checked hose...no leaks or cracks. still having the same result. I also checked the gas valve...24 volts....i"m stumped.
Tags
hvac , ignition issue , york
York Diamond 90 Furnace Smells nightlighter HVAC 4 02-06-2012 08:19 AM
York Diamond 90 P3URB12N Intermittent Ignition Problem kelton56 HVAC 5 12-26-2011 12:17 PM
York Diamond 90 furnace not starting items HVAC 14 12-23-2011 11:57 AM
York Diamond 80- Error code flashes 7 times apclyps HVAC 7 01-04-2011 04:30 PM
York Diamond 90 heater Rob P198 HVAC 1 01-26-2008 09:11 PM
