York Diamond 80 Intermitten Flame - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-16-2009, 12:31 AM   #31
Originally Posted by yuri View Post
Needs cleaning every single year. Keep your fabric softener out of the furnace area. Fumes from it corrode the sensor rapidly.
Thanks for that info. However just to note the fact that my furnace is 11 years old and this is the first time I have cleaned this ! ! !
user is offline   Reply With Quote
Old 12-16-2009, 06:07 AM   #32
An old Tradesmen
Rewards Points: 6,060
You don't really have to change the oil in your car every 3 to 5000 miles either.
It just won't work as well if you push it too long.
Old 12-16-2009, 11:13 AM   #33
LOL....;-)
Liked your analogy. Now It will be first thing on my list.
Thanks.
Old 12-16-2009, 10:38 PM   #34
Seems to be a useful thread and hope it will help others.
Setdyi is offline   Reply With Quote
Old 11-30-2010, 07:25 PM   #35
I also have a York diamond furnace.There is no heat, and I went looking around and the control board is flashing the 5 error code, which the book says is the rollout switch is tripped. I'd like to give a reset a try before a service call. After looking all around the area of the burner, and the electronic valve that controls the gas flow, there is no manual reset switch to be seen. Can you guys give me a pointer that might get me through a cold night?
jmann444 is offline   Reply With Quote
Old 11-30-2010, 07:35 PM   #36
An old Tradesmen
Check the sides and the top of the burner.
Old 11-30-2010, 08:27 PM   #37
there is an off/on switch on the electronic gas valve, nothing else that I see.
Old 12-01-2010, 06:01 AM   #38
An old Tradesmen
Post pics of the burner area. Can tell you where they are then.
Old 02-08-2014, 01:20 PM   #39
Just want to give a feed back on the diag. When I checked the flashing of LED on the main board, it was 7 flashing then break. Called in local York tech to find out if the solonoid is readily available. Per him they do not cell solonoid coils for gas furnace. Entire gas valve needs to be replaced.
Let me give my rational for why I was thinking about the coils. I had similar issue on my gas dryer which will start up for few seconds and then the flame will go away. Igniter will turn red hot but gas will not ignite. I fixed this problem by replacing the solonoid coils and it is working fine. So I jumped to this conclusion.
However talking to one of my friend he suggested to clean the "Flame sensor" (This is on the left side, igniter being on the right) Cleaning this sensor did the trick.
Now I have a heat in the house.
Thanks for Internet and such forums that some one else having similar issue can resolve it in future.
As a maintenance, this sensor needs to be clean ever 2 years or so.
I know this thread is old but I just wanted to say thank you. My furnace had been doing exactly what you described and I temporarily solved it by leaving the fan running all the time. Once I cleaned the sensor it fired the fan right up on it's own.
Thanks!
iwalkbarefoot is offline   Reply With Quote
Tags
error 4 red flashes , furnace limit switches , furnace repair help , york 80 series
York 650.77-N2U flame was lost 5 times vapourit HVAC 1 10-25-2009 09:35 AM
Main blower is very slow on York Diamond 90 dnastrau HVAC 5 08-01-2009 02:11 AM
York Diamond 90 Issues SToronto HVAC 1 03-09-2008 09:35 PM
York Diamond 90 heater Rob P198 HVAC 1 01-26-2008 09:11 PM
York Furnace flame stays on only 5 seconds PatJo HVAC 4 01-19-2007 10:25 AM
