York Diamond 80 Intermitten Flame - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-14-2009, 07:57 PM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 1,096
Check all your wiring. Follow it back from the motor to the board and check for loose wires.
Old 11-14-2009, 08:22 PM   #17
Did that and nothing no rotation. I know the motor is not ceased up because I can spin the spinner with my hand. Everything else is working like it should. I get green light from the board flashing like it should until the flame turns on, then the amber light and then the limit high limit switch opens up high.
Setdyi is offline   Reply With Quote
Old 11-14-2009, 08:49 PM   #18
Hvac Pro
yuri's Avatar
1) If you have A/C put the thermostat fan switch to ON and see if the motor runs or turn the A/C on. 2)You need to follow the wiring diagram, figure out which motor wire is for the heating speed, unplug it and check for 110 volts there when the burner is running. If no voltage then the board is bad. Make sure all the wires from the motor including the white are connected properly. If it has a white molex electrical connector unplug and replug it in and make sure all the wires are pushed in to the connector. You can also stick your meter probe there to check for the 110 volts.
Old 11-14-2009, 09:31 PM   #19
Ok I will do this and let you know what happens.
Old 11-14-2009, 11:03 PM   #20
It runs with AC on but very slow.
Old 11-15-2009, 08:40 AM   #21
Hvac Pro
yuri's Avatar
Sounds like it needs a new capacitor and possibly a new motor. Try Graingers for the capacitor.
Old 11-15-2009, 03:45 PM   #22
Ok so the fact that it is working with the AC and not the furnace means I only have an issue with the capacitor and not the board. I hope this is will correct things.
Thanks or your help. I have a local guy who I have been getting my parts from so I am sure he will have this one as well.
Thanks. Yuri
Old 11-16-2009, 10:49 PM   #23
The heat is on!
YURI,
I replaced the CAP ($8.59) and the unit fired up. All is running well now.
Old 11-17-2009, 06:58 PM   #24
Hvac Pro
yuri's Avatar
Alls Well that ends Well.
Old 11-17-2009, 11:15 PM   #25
Old 12-15-2009, 08:06 AM   #26
Hi Yuri,
I have similar problem on my York Diamond 80 Furnace. Couple of yeasr back I did replace flame igniter and it was ok till this morning. Now I have flame coming in for few seconds and going away. Flame igniter remains red hot after a while flame returns and remains lit for anothe few seconds and then extinguishes. I pulled the top cover out and was observing this cycle. I did feel the click on the top of solonoid coil. Which indicates it is getting proper signal to open up. when the flame comes on. I am thinking replacing solonoid coils. What do you think?
user is offline   Reply With Quote
Old 12-15-2009, 08:11 AM   #27
An old Tradesmen
Rewards Points: 6,072
Restriction in vent system.
Old 12-15-2009, 08:23 AM   #28
No checked that. I can feel good amount of air blow from the furthest register. The air is cold though.
Old 12-15-2009, 10:51 AM   #29
Issue resolved.
Just want to give a feed back on the diag. When I checked the flashing of LED on the main board, it was 7 flashing then break. Called in local York tech to find out if the solonoid is readily available. Per him they do not cell solonoid coils for gas furnace. Entire gas valve needs to be replaced.
Let me give my rational for why I was thinking about the coils. I had similar issue on my gas dryer which will start up for few seconds and then the flame will go away. Igniter will turn red hot but gas will not ignite. I fixed this problem by replacing the solonoid coils and it is working fine. So I jumped to this conclusion.
However talking to one of my friend he suggested to clean the "Flame sensor" (This is on the left side, igniter being on the right) Cleaning this sensor did the trick.
Now I have a heat in the house.
Thanks for Internet and such forums that some one else having similar issue can resolve it in future.
As a maintenance, this sensor needs to be clean ever 2 years or so.
Old 12-15-2009, 07:53 PM   #30
Hvac Pro
yuri's Avatar
Needs cleaning every single year. Keep your fabric softener out of the furnace area. Fumes from it corrode the sensor rapidly.
Tags
error 4 red flashes , furnace limit switches , furnace repair help , york 80 series
York 650.77-N2U flame was lost 5 times vapourit HVAC 1 10-25-2009 09:35 AM
Main blower is very slow on York Diamond 90 dnastrau HVAC 5 08-01-2009 02:11 AM
York Diamond 90 Issues SToronto HVAC 1 03-09-2008 09:35 PM
York Diamond 90 heater Rob P198 HVAC 1 01-26-2008 09:11 PM
York Furnace flame stays on only 5 seconds PatJo HVAC 4 01-19-2007 10:25 AM
