York AC Unit Outside Not Turning On - HVAC - DIY Chatroom Home Improvement Forum
Old 07-24-2006, 11:19 AM   #1
York AC unit outside not turning on
Good Morning, I hope someone can help. I have a York 2 or 3 ton unit outside for my down stair that for some reason as of yesterday when I lower the thermastat nothing happens. When I shut the unit off in the house and restart it I here, I guess the fan motor start, but that is all. I have noticed that recently is has not been blowing the cooleset of air but that could be due to high ceilings and really hot climate. Unit is 6 years old never been serviced. I believe model number starts out like "York HRRA0505360"
Any assistance will be greatly appreciated
ssssg1 is offline   Reply With Quote
Old 07-25-2006, 09:30 PM   #2
Sciencerules
MAS2006's Avatar
Check AC circuit breaker. Listen to outside compressor/fan unit while having someone switch thermostat from off to cool. Both fan and compressor have to come on. The uninsulated coolant line will get warm if compressor functioning.
MAS2006 is offline   Reply With Quote
New A/C unit won't cool in hot temps wishiknewmore HVAC 39 06-28-2012 09:51 PM
York gas heater control board replacement spyvan HVAC 5 12-29-2008 08:12 AM
can I swap a (3) 60watt unit into a spot where I have a (1) 60watt unit? joeyboy Electrical 11 07-29-2007 08:25 PM
Used Central Air Unit? shep28 HVAC 2 04-21-2007 08:59 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
