York AC Blower Overheating - HVAC - DIY Chatroom Home Improvement Forum
Old 07-19-2013, 03:56 PM   #1
Hi, I have a York Diamond 90 Furnace/AC with a White-Rodgers 50A50-241 controller.
The blower will come on at a lower speed that I would suspect it should, run about 20-30 seconds and then shut off. Motor is HOT to the touch. There are no error indications on the controller.
I assume the reason it shuts off is thermal overload but is there a way to tell if the controller or the motor is at fault ?
Thanks,
Glen
ghoughto99 is offline   Reply With Quote
Old 07-19-2013, 08:47 PM   #2
An old Tradesmen
Rewards Points: 7,328
Moved to HVAC forum.
Old 07-19-2013, 08:48 PM   #3
An old Tradesmen
May be the capacitor.
Old 07-20-2013, 09:43 AM   #4
You were spot on BeenThere. 8 bucks later and I am back up.
Thanks.
Tags
air conditioner , blower fan stops , york
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Blower Kicks off on York Handling Unit on Heat Mode Swampdawg HVAC 0 10-18-2012 07:12 PM
York variable speed blower motor issues reubj HVAC 12 06-11-2012 09:21 PM
York furnace - blower motor works intermittently on medium speed jeremyp969 HVAC 4 04-18-2012 12:37 PM
York Furnance Blower Will Not Shut Off mrinck HVAC 5 02-07-2011 02:16 AM
