York 90, Burn Smell, How Warm Should Inducer Motor Be? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-14-2012, 07:40 PM   #1
York 90, burn smell, how warm should inducer motor be?
Hi
I have a York 90. One day we smelt a rubber sort of burn smell pretty bad.
Then it seems to have stopped doing it. However, the furnace seems to still be working fine and I don't hear any weird sounds from motors. I can't tell what could be wrong yet. My wife thinks she smelt it again 2 days later.
I was wondering how hot should the inducer motor be while the furnace is running? Has any one ever touched their inducer motor or measured its temp while running and could share this info?
doneit is offline   Reply With Quote
Old 02-14-2012, 07:44 PM   #2
Chances are if it's coming from the furnace it's a motor or electronic component going bad.
You have a clean filter in it?
hvac5646 is offline   Reply With Quote
Old 02-14-2012, 07:45 PM   #3
HVAC Tech/ Browns Fan
Draft motor can be hot when running but true way is get amp drawl on it. Did you feel blower motor when cycling off?
Tator1076 is offline   Reply With Quote
Old 02-14-2012, 10:59 PM   #4
Yes, I replaced filter, vacuumed motors off. Cleaned trap, measured starting capacitor capacitances.
I measured 65 degrees C on the induction motor case, feels almost too hot to touch and keep hand on when running.
Feeling the blower motor it didn't feel too warm, not hot like the other motor. (Its hard to get to my blower motor). Squirel cage feels easy to turn.
So now I'm wondering how hot that induction motor should be when running?
Old 02-14-2012, 11:30 PM   #5
As tator said, you have to get an amp draw on it.......temperature dose not tell the story......amp draw does.Motors are rated in amp draw not thermal tempature. Remember that most inducer motors turn at a higher rpm then your car engine dose at highway speeds..........its a hard working motor for sure.
dosy777 is offline   Reply With Quote
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Smell when boiler runs? dave12345 HVAC 13 11-11-2013 08:08 AM
York Diamond 90 - 3 flashes and a humming inducer motor okwiater HVAC 2 11-28-2010 03:45 PM
How to get rid of burn smell in basement ilyaz General DIY Discussions 3 08-08-2010 02:44 PM
Furnace burn smell Red Squirrel HVAC 5 06-06-2010 01:07 PM
