YJ SuperVac 93560 - HVAC - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 01:50 AM   #1
JJboy's Avatar
YJ SuperVac 93560
I don't remember having received females brass fitting. Do I need to cap one of the entrances of intake?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 05-18-2011, 07:39 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
I have two of those. Neither came with brass fittings, just those black caps attached to the pump.
Doc Holliday is offline   Reply With Quote
Old 05-18-2011, 09:18 AM   #3
JJboy's Avatar
Old 05-18-2011, 11:55 AM   #4
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
I have one with just the black caps.
Big N8 is offline   Reply With Quote
Old 05-18-2011, 09:08 PM   #5
You either use the 1/4 or 3/8 or both. But whatever one you are not using make sure it's got cap with a o-ring. I use 3/8 as much as possible. Go out and buy some 1/4 female by 3/8 fittings and a couple 3/8 hoses at united refrigeration or wherever you buy your supplies.
Hubcap626 is offline   Reply With Quote
