#16 | |
Yet another bathroom exhaust fan venting questionQuote:
If I'm reading correctly, they suggest running metal flashing even on the sides of the window trim? Not something generally practiced in this neck of the woods. Or the four different installers I interviewed to stucco the home I live in now all did/do it wrong. Thanks again for the informative links. Regards, Jules
You can't fix stupid..... |
#17 |
Master of none
Don't even think of a ventless bathroom fan. The purpose of a bathroom fan is to exhaust moisture laden air. You will simply have to find a way to run your vent pipe between floor joists or box it in if it can not run between joists.
#18 | |
You'll want to talk to your HVAC contractor about that. Adding fresh air to the A/C system does eat up a bit of tonnage, and it should also be filtered so as not to create a dirty evaporator coil. Also down here, it is generally the HVAC contractor that handles the bthrm ventilation, so, unless it's something you want to handle yourself, that's another subject you could ask him about. Mark Last edited by rightit; 03-09-2011 at 07:16 PM. |
#19 |
You could put a larger roof vent in, like a 6" and hook all your fans into it. But you would have to remove the damper from the 6" roof vent and install 4" backdraft dampers on each bath fan. You can get good backdraft dampers at any good Hvac supply house.
#20 | |
Issues: - floor joists run perp to the wall in the pic (perfect if not for windows) - 7' - 9" ceiling height on the first floor - Frig and cabnitry to one side - LVL and steps to other side and end - 2x4 wall construction - bedroom directly above - etc....
#21 | |
Thanks for chiming in. Regards, Jules
#22 | |
thanks. Jules
#23 |
Generally you place these vent terminations on the back roof of the house. Not sure which slope you'll be placing your possible solar panels on (presumably the slope that receives the most sun), but a vent cap like this might be acceptable to you and should be pretty discreet. It's profile is less than 5":
http://www.grainger.com/Grainger/BRO...905?Pid=search Mark |
#24 | |
Thanks for the link! Jules
| Display Modes | |
| Question regarding bathroom exhaust fan | DownRiverGuy | HVAC | 2 | 01-15-2011 05:18 PM |
| New Bathroom Drain Question | militaryman | Plumbing | 1 | 01-06-2011 10:09 AM |
| Bathroom 20A Dedicated Question... | bparise | Electrical | 5 | 10-11-2009 01:39 PM |
| Bathroom exhaust fans | PirateKatz | HVAC | 7 | 11-18-2008 04:09 PM |
| Venting up vs out for bathroom, kitchen | pcampbell | HVAC | 12 | 11-15-2008 11:02 AM |
