Yellow CSST Question(s) - HVAC - DIY Chatroom Home Improvement Forum
Old 12-23-2011, 08:31 PM   #1
Rewards Points: 31
Yellow CSST question(s)
Greetings............we are presently renovating a home and plan to use LP gas for a forced air furnace, a tankless HW heater, a gas stove, and a log set.
Our local propane company installed a single yellow Tracpipe from the supply tank with 3 tee's branching off to the various appliances. The system was air pressure tested and passed by our local building official who later contacted me with concerns about the amount of splices in the tubing. He wished to verify that the particular brass fittings used were specified by the manufacturer for burial in a wallboard closed ceiling bay or similar confined space.
I later checked with the gas company and they verified with the building department that the correct fitting were used so the system is good to go as far as the gas company and the building department are concerned.
Is this type of installation a common practice and should I have any concerns here? Thanks.
Rustygaff is offline   Reply With Quote
Old 12-23-2011, 08:38 PM   #2
Rewards Points: 582
if the city and gas company are happy with it I guess its ok then......I would not want any fittings behind the walls or in ceiling if at all possible even if it cost more....we plumb to a manifold with valves then branch to each fixture..JUST ME....fittings accessable...
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (12-23-2011)
Old 12-23-2011, 10:31 PM   #3
no worries......trac pipe, warflex, and a hundred other names it is sold under, its the gas line of the 21 st centrury.Its easy to work with, goes in 10 times faster then black pipe and is very cost effective. I have ran miles of it and never had a single problem with it.
harleyrider is offline   Reply With Quote
Old 12-23-2011, 11:07 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Dont forget it also looks like crap as installed by 99% of the installers/homeowners out there!
Have you ever seen a house that was gas piped with it without proper grounding/bonding after being hit by lightning back in the days before the code changes ?
Would burn pin holes all the way down the line ,ive torn out miles of it and replaced with black pipe.
Anyway ive got to go flip the 8 track in my player and finish piping a water heater in
plummen is offline   Reply With Quote
Old 12-23-2011, 11:47 PM   #5
Sounds like a bunch of hacks put in the jobs you been on .............get better help.
Old 12-23-2011, 11:55 PM   #6
plummen's Avatar
None of my help would install any of that stuff on any of my jobs under penalty of redo on their own time!
Ive got another hack job/remodel somebody else did that i looked at today i have to start redoing all the wiring/plumbing on tomorrow.
To their credit whoever did the framing/drywall did nice work!
The guys that did everything else need to be beaten with their own tols though!
Ill take some pictures tomorrow!
Old 12-24-2011, 12:00 AM   #7
Rewards Points: 6,652
It sounds like the inspector is still green, and either questioning what they have heard from the old timers, what they have learned in class, and what the actual code states. As long as your supplier follows state and national code, I would ask the AHJ to back up what they are stating is contridicting, by showing the section, if they red tag you.
Old 12-24-2011, 07:04 AM   #8
Rewards Points: 31
Thanks for all the quick replies guys. The local building inspector did approve the install providing the gas company used the Tracpipe approved Autoflare fittings and the pipe is properly bonded to our electrical ground system.
My only concern is whether or not 3 Autoflare tee's buried in a ceiling are safe regardless of what the manufacturer and the gas salesman state.
If I opted to pull the Tracpipe and install "home runs" linking all 4 appliances to a manifold, it would be pretty costly I imagine . If this option were employed, I would go with an electric stove, delete the fireplace, and only feed the hw heater and furnace with gas.
As a side note, I mentioned earlier that the system was air pressure tested when installed. A hand pump was used to pressurize the system to about 10 to 15 PSI on the attached gauge. Its been a couple of weeks now and cold here in the northeast. I noticed the pressure has dropped to about 7 or 8 #. My HVAC guy told me cold temps will cause the pressure to drop even though the system is airtight. Some use nitrogen for testing to avoid the pressure drop issue I was also told.
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Why has my white paint work turned yellow S. Alton Painting 6 07-07-2011 11:52 AM
Insulation under staircase...yellow dust?? CanRulez Insulation 0 03-20-2011 08:35 PM
CSST Gas Line Lightning Strike and Electrical Issue duteberta Electrical 18 07-29-2009 05:01 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
