Y1 Or Y2? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 09:11 PM   #1
Y1 or Y2?
The old thermostat used Y for cooling, the new one has Y1 and Y2. Which one do I hook up to?
max2k is offline   Reply With Quote
Old 10-04-2010, 09:22 PM   #2
If you have one stage of cooling Y1 is the hook up.
If you have two stages of cooling then Y1 is first stage and Y2 is second stage of cooling.
Artco is offline   Reply With Quote
Old 10-04-2010, 10:06 PM   #3
Thanks a lot for the quick help Artco, I really appreciate it.
Old 10-05-2010, 03:49 AM   #4
Seasoned DIYer
Rewards Points: 150
The thermostat should have a setting. You will use Y1 as if it is plain Y, but you need to make sure the thermostat is also set for single stage cool mode.
HVAC_NW is offline   Reply With Quote
Old 10-05-2010, 12:44 PM   #5
Thank you for your help HVAC_NW, I got it working yesterday. It seem to work as it should in cooling and heating mode. I just double check on cooling mode setting and it set at stage 1 by default. Thank you for help in full detail.
