Xv80 Intermittent Blower Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 11:45 AM   #1
xv80 intermittent blower problems
Furnace comes on (flame) but not blower, then trips out on overtemp. This is an intermittent problem that occurs infrequently, every couple of days or even a month. Last week fan would not run at all, repairman replaced the module on the motor and all was fine for 3 days and now back to the intermittent blower not running. I just power down the furnace and then power back up and all is fine till the next time. Any guesses what might be the problem??
Don
drmiller7 is offline   Reply With Quote
Old 03-05-2012, 12:08 PM   #2
how
Rewards Points: 1,102
Problem Motor, motor lead connections or board.
Trying to see if the motor is being powered or not, when it should be running but isn't, when the problem is intermitant is difficult.
Right now it sounds like your blower intermitantly fails to run, furnace overheats and locks out. You turn off the power thereby resetting the now cooled furnace and everything starts up fine again. Amp testing the motor may give you some clues with a long heating run.
how is offline   Reply With Quote
Old 03-05-2012, 06:01 PM   #3
Rewards Points: 582
perhaps fan relay on control board sticking on and off..... what module did he replace....picture of furnace would help.
Carrier Weathermaker 9200 blower problems preacher01 HVAC 4 06-01-2012 07:24 AM
trane xv80, blower on, burner not igniting. Natuss HVAC 1 11-04-2010 05:32 PM
comfortmaker rpj2 blower wheel problems nuclearjesus HVAC 3 11-22-2009 09:14 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
Intermittent gas furnace problems dcoz HVAC 1 01-16-2006 10:22 PM
