Old 01-26-2012, 03:13 PM   #1
XL80 Trane Furnace Fan won't turn on
I have an XL80 Trane Furance. The thermostat calls for heat, the draft fan starts, furnace ignites, but fan doesn't turn on. Replaced the upper limit switch, and control module, and still have the problem. Eventually the upper limit switch shuts everything down when too hot. Let it cool, turn the fan on constant and furnace fires and heats as it would nromally. HELP
jenlou is offline   Reply With Quote
Old 01-26-2012, 03:59 PM   #2
is there 120 vac going to the motor.....what is the UF reading on the capacitor?
harleyrider is offline   Reply With Quote
Old 01-26-2012, 05:02 PM   #3
Part of the Clover Leaf
u gotta counterflo furnace. Your motor is probably shot..might be a capacitor too.
When was the last time u changed the filter.
hvac5646 is offline   Reply With Quote
Old 01-26-2012, 05:56 PM   #4
how
hey HVAC5646
If his fan is OK switched to constant run, are you thinking that the lower heating speed windings are the problem? Capacitor choice confuses me if the cooling speed is fine.
I think I'd be first looking if the heating blower connection on the board is getting power as Harley suggested.
how is offline   Reply With Quote
Old 01-26-2012, 06:59 PM   #5
Originally Posted by how View Post
hey HVAC5646
Yeah i'd agree with that (since I missed the part of the OP trying the Fan ON position) .
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 08:59 PM
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 04:22 PM
Can't turn furnace fan on from thermostat control cnnd2010 HVAC 0 06-18-2010 11:37 AM
furnace won't turn on energybill HVAC 7 02-06-2009 08:22 PM
Trane xl-90 2 stage furnace problems ikon07 HVAC 5 03-14-2008 09:14 AM
