Xl 1800 Cond Fan Motor Water Inside - HVAC - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 09:45 PM   #1
Xl 1800 cond fan motor water inside
Have friend with problem with fan motor burnt out, was replaced in march
Now out again, local tech says motor is fried and full of water. I checked with
Parts dept. Said there may be a plug which must be moved to top of motor to prevent this condition from occurring again. Went over there and took top off
Looked over the motor really well, couldn't find any plug top or bottom. Maybe this motor doesn't have this plug. Any way just wondered if anyone has ever heard of this type of problem?
Trane tech is offline   Reply With Quote
Old 07-13-2011, 09:54 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Nope but I did have a fan coil relay that was welded shut (normally open) mysteriously fix itself overnight, last night.
One less recall for me!
Doc Holliday is offline   Reply With Quote
Old 07-13-2011, 09:57 PM   #3
JJboy's Avatar
Ventilation openings in shield and/or frame prevents drops of liquid from falling into motor within up to 15 degree angle from vertical.
I think he was talking about this. The outdoor fan motor is protected with a cover.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
run spliced lamp cord inside a wall? denemante Electrical 20 12-17-2010 09:35 PM
How much conductor inside J-box? deko Electrical 9 09-08-2010 10:26 PM
AC tripping breaker inside the unit lauratodd HVAC 1 09-01-2010 05:30 PM
Basement moisture - why not seal inside wall? BRO931 Building & Construction 10 08-30-2010 01:47 PM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-05-2005 11:03 PM
