XE1000 Condenser Fan Install - HVAC - DIY Chatroom Home Improvement Forum
Old 09-30-2012, 01:20 PM   #1
Hello! I am trying to figure out how to wire in a new Trane MOT 3125 condenser fan motor into my 1993 XE 1000 heat pump.
It has an AO Smith motor in it now that has bad bearings. A tech replaced the original motor with an AO Smith motor a few years ago and I suspect he did away with wires needed for the Trane motor. The Trane motor has 3 wires, black, brown and purple.
The AO Smith has 4 wires, black, white, brown and brown with a white stripe. The 2 brown wires currently go to a small start capacitor. The black goes to a circuit board and the white goes to what appears to be a relay.
Now I cant figure out what to do with these 3 wires on the new motor.
Any help will be greatly appreciated!
Ryan2002 is offline   Reply With Quote
Old 09-30-2012, 02:49 PM   #2
Houston204's Avatar
Rewards Points: 556
Did you buy a capacitor with your new motor?
Was it a dual capacitor?
Houston204 is offline   Reply With Quote
Old 09-30-2012, 03:05 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
as stated you need a dual run capacitor.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-30-2012, 06:50 PM   #4
Thanks! I finally found the schematic. It's a different model that uses a separate capacitor and I did buy one. And the tech must have tossed the one missing wire that ran from the relay T2 over to the terminal on the small cap where the purple plugs in. The brown goes to the other terminal on the cap and the black goes to the defrost board where the AO Smith's black wire was.
It's running now and quiet as a mouse! Thanks again for the help!
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 03:18 PM
Should I install interior doors before floor? pttcc Flooring 13 11-23-2010 10:02 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 09:49 PM
AC condenser install quote question amdspitfire HVAC 3 08-25-2008 10:56 PM
