XE 1000 Noise From The Compressor But Not Running - HVAC - DIY Chatroom Home Improvement Forum
Old 02-08-2010, 06:15 PM   #1
XE 1000 Noise from the compressor but not running
My outside unit (heat pump) is not running. I was troubleshooting with help from some of the guys here and I thought it was the capacitor. I just put in a new capacitor and it did not do anything. While I was there I saw that some of the lines going to the coil had a light frost on them. Is that an indication of low refrigerant? and if that is the case, will that cause the fan not to run while the compressor makes a humming noise?
berr3555 is offline   Reply With Quote
loud jackhammer-like noise from hot water pipe omar Plumbing 15 01-08-2012 01:53 PM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
Trane 1100 XE- Outside unit making humming noise Momof2 HVAC 0 09-03-2009 11:25 AM
Pipe noise upstairs bathroom when running only warm water dial2fast Plumbing 1 12-03-2007 11:39 PM
water heater noise boman47k Plumbing 5 11-28-2007 06:31 AM
