X13 Motor Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 09-23-2012, 12:17 PM   #1
X13 Motor problems
I have a Payne air handler with a GE x13 motor. When the system is on the x13 will turn slowly but not come up to speed enough to push air. I have verified it is getting power from the board. Is the motor shot?
brentalight is offline   Reply With Quote
Old 09-23-2012, 12:36 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
is this a newly installed system? is this a call for blower only or a/c or heat?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-23-2012, 02:16 PM   #3
Its a fairly older system although I believe the motor might have been replaced at some point. The motor will not run an fan, heat or A/C. I can hear what I think is the relay clicking when the unit is engaged at the thermostat and then the motor simply spins very slowly.
Old 09-23-2012, 02:20 PM   #4
JJboy's Avatar
have you tested the capacitor?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-23-2012, 02:28 PM   #5
AKA HVACTECHFW
no capacitor on a x-13 motor, JJ
OP, where did you get that it was a X-13 motor?
IT IS WHAT IT IS
The Following User Says Thank You to hvactech126 For This Useful Post:
JJboy (09-23-2012)
Old 09-23-2012, 02:40 PM   #6
I opened the unit and can read it right off the motor. It is a GE X13 1/3 HP 208-230 Volt. I was hoping if it was shot I could just replace it but it looks like they have to be programed. Does that sound right? Is there something else that could be causing it to not spin up correctly? We were able to verify power coming from the board to the connections to the motor.
Old 09-23-2012, 03:18 PM   #7
AKA HVACTECHFW
which connections did you check? http://www.comfortgurus.com/specs/pr...ce%20Guide.pdf X13 diagnostics begin on page 13
IT IS WHAT IT IS
ben's plumbing (09-23-2012)
Old 09-23-2012, 07:00 PM   #8
An old Tradesmen
Rewards Points: 7,270
X13 needs to come from OEM. It will be preprogrammed then.
The Following User Says Thank You to beenthere For This Useful Post:
Old 09-24-2012, 11:41 AM   #9
Bummer. That is going to be pricey then. Thanks to all for the responses. I will try the troublshooting provided in pdf link above. Hopefully it isnt the motor and will be something cheaper to fix.
