X13 Blower Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 03-03-2012, 02:17 PM   #1
x13 blower motor
Nordyne gas heat, elec. ac. Model # GR4GD-030k072X, My question is , The winding of the x13 blower motor does not seem to be burnt, no burnt smell. Am I able to replace just the back terminal part of the motor ? It seems to have a program number on tag. XL0124_0
boner is offline   Reply With Quote
Old 03-03-2012, 02:54 PM   #2
HVAC Tech/ Browns Fan
This motor a v.speed?
Tator1076 is offline   Reply With Quote
Old 03-03-2012, 11:45 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
x13 motors are not VS.
The X13 motor is a permanent magnet, three phase, brushless DC motor. A single phase drive is attached to the motor to control it for air over direct drive indoor blower applications.
It is designed to operate in constant torque mode with up to five discrete tap settings for OEM applications. For development use, sample motors can be programmed for variable torque operation to expedite airflow characterization in the unit.
NO, do not try to replace just the back terminal part.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
Tator1076 (03-05-2012)
Old 03-04-2012, 12:35 AM   #4
REP
Save yourself a world of trouble and get an exact factory replacement.
REP is offline   Reply With Quote
Old 03-04-2012, 10:46 AM   #5
Houston204's Avatar
Rewards Points: 556
The X13 would require replacement of the entire motor.
Houston204 is offline   Reply With Quote
Trane XL80 blower motor part number? keverino HVAC 17 01-10-2012 09:01 AM
Old Rheem Air Blower Motor Wiring Problem CompoundNetwork HVAC 3 11-20-2011 03:51 PM
Blower motor: Emerson to GE threeonesix HVAC 12 08-25-2011 03:59 PM
Wiring a replacement blower motor bodtchboy HVAC 17 08-11-2011 10:05 PM
Inside Blower motor keeps running crawlerchris HVAC 1 12-19-2009 08:01 PM
