X Wire On Old Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 03-28-2008, 11:14 PM   #1
X wire on old thermostat
I have a heat pump with emergency heat function. Changing the old thermostat to a Rite Temp 8010. All the connections corresponded just like the installation manual said. Only question I had was the old thermostat had a black wire connected to an X terminal. The new thermostat, which has 2 AA batteries, said to tape off the X wire from the old thermostat. I did that and everything seems to work fine (didn't check AC today though). I also pulled the panel off the heat pump unit in the basement and the black wire in question above is connected to a C terminal (apparantly the common side of the 24 VAC transformer? I thought I read somewhere that I could go ahead and connect that black wire from C in the basement to C on the new thermostat and extend battery life? Or should I just quit while I'm ahead and leave well enough alone? Thanks.
Jellybean is offline   Reply With Quote
Old 03-29-2008, 08:14 PM   #2
biggles's Avatar
if the new stat info calls for the C from the furnace hook it up for the comon sidde of the TR so you have a true 24V at the subbase.the newer stats with the larger LED screens and more digital options calls for a solid 24Vs the battery s to keep the stat info constant during a power failure until the power comes back up.
Old 03-29-2008, 08:35 PM   #3
you can hook up the wire to the c terminal on the tstat and then get rid of the batteries .
hvacdad211 is offline   Reply With Quote
Old 03-30-2008, 07:14 AM   #4
Thanks for your help. I appreciate it.
Question(s) about 2 wire Thermostat - need help, won't turn off! WestsideAudioFan Electrical 13 01-17-2014 04:24 PM
8 wire to 4 wire thermostat help needed dj petey Electrical 5 01-19-2008 09:11 AM
Wiring a Noma Programable Thermostat 111jag General DIY Discussions 1 10-14-2007 10:13 PM
8 wire to 4 wire thermostat help needed dj petey HVAC 5 04-15-2006 12:20 PM
