Wrong Metal For Furance Exhaust ? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-29-2013, 05:33 PM   #1
Rewards Points: 12
Wrong metal for furance exhaust ?
So Im up on the roof and i notice the out side of the Exhaust pipe Is rusted away and the cap is missing off the exhaust pipe. from the attic there is blown in insulted and its all dis colored from the metal rotten away, it left the white blown in insulted yellow like the pipe on the roof
What should be done to fix this issue?
is everything all good except the cap missing?
it seems to be a low gauge steel for the flashing kit/ pipe slide over the inner pipe which seems to have no damage.
or did it rot out so bad because there was 2 different types of metals used?
Next doors
Dnbtrack is offline   Reply With Quote
Old 07-29-2013, 06:21 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,318
they use galvanized metal for those and it gets corroded and eaten away by moisture and acid rain does not help either. needs to be replaced with a new one, unfortunately none of them are made of stainless steel as the cost would be prohibitive.
Old 07-29-2013, 06:26 PM   #3
Rewards Points: 582
wow that has to be really leaking on a rain????ben sr replace is an understatment...
Old 07-29-2013, 06:41 PM   #4
Rewards Points: 12
So it needs a flashing kit and a sock type pipe to going iver the original one? I seen several of these very very old and not even phased by weather? Do you think it was the product they used as on the same street there is several rotted out so the builder probably used the same one threw out the street, the hvac guys I mean?
Its a very very thin gauge
What would the cost be of these parts and which would I need to buy?
Old 07-29-2013, 09:15 PM   #5
Experienced HVAC Tech
HVAC1000's Avatar
It's call double wall or type B vent. You should replace whatever is rusted through. What's your location, and what is common weathers there?
HVAC1000 is offline   Reply With Quote
Old 07-29-2013, 10:58 PM   #6
Rewards Points: 446
The damage looks to be from the flue gases condensing at the cap and dripping down onto the outer galvanized pipe and destroying it. Either that or you live real close to the ocean.
No matter the reason they need to be replaced back to where the pipe is not damaged.
old_squid is offline   Reply With Quote
Old 07-30-2013, 05:19 AM   #7
An old Tradesmen
Rewards Points: 7,414
You'll need to look at what brand it is. And then you have to use that brand. Unless you run all new from the furnace up.
The attic height may be such, that the B vent is cooling too much in the attic. May need to wrap it with a non combustible insulation in the attic.
Old 07-30-2013, 06:18 AM   #8
PoleCat's Avatar
Rewards Points: 1,646
There are stainless steel pipes available but as mentioned they are not an easy buy. I just passed on them myself in favor of the galvanized.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Grounding Metal Boxes and Outlets - Confused by Something Simple ALFisher Electrical 42 04-28-2015 12:14 PM
Clearcoating a Stripped Vintage Ferrous Metal Medicine Cabinet? Lovegasoline Painting 15 08-31-2013 09:32 PM
old pull chain metal wall mount exhaust fans mssjam Remodeling 3 10-13-2012 04:33 PM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 01:23 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
