Wrong Copper Tube?????? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-31-2011, 06:10 PM   #1
JJboy's Avatar
Wrong copper tube??????
I got these 2 new toys. The copper is ACR/MED Type L. The copper tube is denting or cracking. Please see the images.
http://img200.imageshack.us/img200/5815/img0235us.jpg
http://img829.imageshack.us/img829/2750/img0236j.jpg
http://img194.imageshack.us/img194/5964/img0237fw.jpg
http://img807.imageshack.us/img807/2586/img0238u.jpg
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 05-31-2011, 06:31 PM   #2
What's that first tool JJ,some kind of fancy pants swedging tool? Soft copper only on the tubing bender.
Old 05-31-2011, 07:20 PM   #3
JJboy's Avatar
Hydraulic tube expanding and Yellow Jacket Benter.
What is the Ref number for this soft copper?....
Old 05-31-2011, 08:51 PM   #4
Not sure what you mean JJ. Soft copper comes in rolls,hard copper in sticks. Refrigeration copper comes cleaned and capped and has the dry nitro smell when you open it,can be hard or soft. Plumbing copper usually comes open ended.
Old 05-31-2011, 09:14 PM   #5
JJboy's Avatar
I found a piece of soft copper. You were right Marty. Thanks
Old 05-31-2011, 10:16 PM   #6
An old Tradesmen
Rewards Points: 6,160
In a pinch. If all you have is hard drawn copper. Heat it. then it will become soft, and you can swedge it, or bend it. takes a little practice though.
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 05:03 PM
Sweating copper pipe - what was I doing wrong Fortitude Plumbing 26 09-15-2010 10:12 PM
pex vs copper piping sizes dichroic Plumbing 6 07-28-2009 10:35 AM
Installing copper gutter to replace some concrete tiles whattodo Roofing/Siding 2 07-28-2009 08:28 AM
Copper pipe size question greymous Plumbing 18 01-30-2009 05:02 PM
