Wow! Heat Pumps Rock! - HVAC - DIY Chatroom Home Improvement Forum
Old 11-23-2010, 10:09 AM   #1
Rewards Points: 392
It is 24 degrees outside and my heat pump is still able to keep our house warm.. It is holding steady at 65 degrees.. At 24 degrees it still costs 15% less to run then the 92% efficient furnace we have for backup heat.
It looks like the balance point for our house for 70 degrees inside is about 30 degrees outside. That also calculates to a house load of 7 BTU/sq ft/Deg F/Day or 162 watts/degree F. Our house is 1900 sq/ft located in Portland OR and built in 1972. Windows are upgraded, but most of the walls have R6 isolation in them. I put in a 2.5 ton heat pump. When I got quotes, the load calcs people gave me put me in 3 ton to 4 ton units. I'm glad I stuck with the 2.5...
zootjeff is offline   Reply With Quote
Old 11-23-2010, 11:21 AM   #2
thats awesome. getting a heat pump is the one thing I regret about my system.
About a year ago I purchased a lennox 92% furnace, coil, and condenser. I have a connection at lennox through work and got the system pretty much at cost. I had been told about heat pumps but figured I didn't need one.
The system has been great and dramatically lowered my heating and a/c bills, so I often wonder....how much better could it be. haha.
moopey is offline   Reply With Quote
Old 11-23-2010, 03:10 PM   #3
Rewards Points: 392
Did you mean to say "not getting a heatpump"? You just have AC right?
Old 11-23-2010, 07:24 PM   #4
yes it that is what I meant to say.
Heat Pumps EL Williams HVAC 2 04-07-2010 08:57 PM
Heat pump and Honeywell 8000 questions. jyoderz HVAC 14 04-06-2010 02:26 PM
heat pump cut off set point oldswab HVAC 4 12-02-2009 02:09 PM
Programmable thermostats, heat pumps and aux heat Crunkleton HVAC 3 04-21-2009 05:17 PM
Are Trane heat pumps and Am Std exactly the same? jgtaylorjr HVAC 1 06-01-2008 09:35 PM
