Worth The Switch To Metal/Permanent Air Filter? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-24-2008, 10:08 AM   #1
Worth the Switch to Metal/Permanent Air Filter?
I have a 18x24x1 filter that I am thinking about replacing with a permanent filter. It seems like a no-brainer as it would seemingly pay for itself over time.
Are there any drawbacks to metal-filters? If they are a good idea, what brands are the best?
wallix is offline   Reply With Quote
Old 12-24-2008, 02:46 PM   #2
An old Tradesmen
Rewards Points: 7,338
They have very high PDs, and are generally too restrictive.
Old 01-12-2009, 08:32 AM   #3
Rewards Points: 270
What is PD?
Any knowledge on the "BoAir" -it seems to be the one that comes up most when looking at electrostatic washable filters.
pcampbell is offline   Reply With Quote
Old 01-12-2009, 05:35 PM   #4
Rewards Points: 150
Originally Posted by pcampbell View Post
What is PD?
pd = pressure drop
Which is HVAC jargon used to descibe the back pressure the filter imposes on the blower fan. It is the pressure difference across the filter. The more resistance the filter has the higher the PD the higher the backpressure the harder the fan has to work to move the same amount of air. If the filter is too restrictive, depending on the blower, it could cause reduced airflow or higher energy usage trying to force the air through the filter. Typically the cheap blue fiberglass filters are the least restrictive and have the lowest PD, however they are not the the best filters for removing dust or pollen.
Key1
In the land of the blind....the man with one eye is king....
key1cc is offline   Reply With Quote
Dimmer Switch Vandiyan Electrical 21 12-15-2008 07:23 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
