Worth Insulating Pipes? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-13-2009, 08:55 PM   #1
worth insulating pipes?
wondering if it's worth insulating the domestic hot water pipes in the basement. what about the pipes for the radiators running around the perimeter of the basement? worth insulating, or better to let the basement get a little warm air off of them?
thanks.
wombosi is offline   Reply With Quote
Old 02-13-2009, 09:14 PM   #2
I insulated my hot water pipes, but not the heat pipes
Heat pipes help heat the basement & the floors for the 1st floor
Hot water pipes losing heat means my shower will get colder faster
When my new water heater was installed it came with a 30" piece of pipe insulation. I checked & only the pipe near the water heater was hot, but I put the pipe insulation on. The next day I checked it again, the pipe at the end of the 30" insulation was hot - not warm - hot. I added another 4' piece I had - checked the next day - the pipe at the end was now pretty warm. After that I bought enough insulation to do all the hot water pipes
I figure with a HW tank it reduces the stand by loss
Old 02-13-2009, 09:24 PM   #3
awesome. thannks man. that's cool news.
i'm going shopping for an electric water heater at HD tomorrow.
you think a 40 gallon will do me for two bathrooms, two kitchens?
any particular brand or other info i should look for?
thanks again.
Old 02-13-2009, 09:35 PM   #4
I went with a 50g since its a 4 bedroom house & we have a son. Plus MIL is here 2 days a week & great grandmother now & again
Plumbers can give you an idea of a good brand
We ended up with a Whirpool 12 year, but some on here have said that it is not a good brand. It's been over 3 years - no problems knock on wood
Old 02-15-2009, 06:32 PM   #5
tk03's Avatar
Rewards Points: 150
If you do a thermal trap you only need to insulate a short piece of domestic hot pipe. It will stop the hot water movement out the pipe through thermal circulation.
tk03 is offline   Reply With Quote
insulating pex pipes ibs325 Plumbing 28 03-29-2012 03:59 PM
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Insulating water pipes? CooperChloe Building & Construction 4 02-04-2009 11:11 AM
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 01:18 PM
Insulating Steam Pipes Densec General DIY Discussions 5 01-04-2009 09:14 PM
