Woodstove Venting - HVAC - DIY Chatroom Home Improvement Forum
Old 09-15-2008, 08:09 PM   #1
woodstove venting
Is it necessary to install the woodstove vent straight up? I would have to do a stair step pattern in order to position the stove where I would like it. Would that cause any problems?
ekulrenlig is offline   Reply With Quote
Old 09-15-2008, 09:58 PM   #2
Registered User
Termite's Avatar
It can depend on the stove. There are so many different manufacturers and applications that the code remains pretty vague on the subject. The code basically refers you to the manufacturer's instructions and requires that they be followed.
Elbows certainly reduce flow, and aren't a good thing. Straight vertical is much more ideal. If you must use elbows, I imagine that 45's are going to be bettern than 90's.
Check the instructions. If you don't have them, contact the manufacturer.
Old 09-16-2008, 08:07 PM   #3
Well I found a manual online. It showed many figures with the stove pipe having multiple 90 degree turns. The only thing it said was to avoid unecessary turns, and also to slope any horizontal pipe upward toward the chimney at least 1/4" for each foot of horizontal run. So there we have it, I guess.
I am planning on using a 6 to 8 inch adapter for the pipe diameter. Will this help reduce the amount of flow restriction I am creating by installing multiple turns?
Anybody know where I can find stove pipe for cheap?
Old 09-17-2008, 11:19 AM   #4
Another DIY Zombie
Rewards Points: 264
Maybe a Lowes, HD or Central Tractor (Tractor Supply Center), or your local woodstove dealer....
javan is offline   Reply With Quote
Furnace venting questions Mastiff HVAC 9 12-05-2012 05:51 PM
Blocked Attic Soffit Vents on North Side - How to Improve Venting Jes Roofing/Siding 5 05-06-2008 09:35 AM
woodstove JAVAMAN General DIY Discussions 1 12-05-2007 02:31 PM
Crawl space venting... MLO Building & Construction 2 09-23-2006 03:18 PM
