Woodstove Pipe Causing Draft - HVAC - DIY Chatroom Home Improvement Forum
Old 10-24-2011, 08:50 AM   #1
Woodstove pipe causing draft
I recently installed a woodstove in the livingroom fireplace. The pipe comes out of the back of the woodstove, into the fireplace and up the flue. The only propblem with this set-up is that the flue has to stay open because the pipe goes through it. I'm worried that the heat will easily escape through open flue when the stove is not in use. Is there a way I can insulate the flue around the chimney pipe so the heat can't escape?
Seannyt is offline   Reply With Quote
Old 10-24-2011, 09:32 AM   #2
DIY staff
Rewards Points: 7,174
Post a picture of your set up---something doesn't sound right.
Old 10-24-2011, 12:33 PM   #3
Rewards Points: 154
flue
sounds like a flue liner and it should be sealed at the roof line.
Patrick Eubanks is offline   Reply With Quote
Old 10-26-2011, 01:33 PM   #4
I don't have any pics, but the pipe does not go all the way to the top of the chimney. It reaches just past where the flue liner begins. But now the chimney damper is open because the pipe has to go through it and I'mworries that in the winter, the heat will escape through the open damper.
Old 10-27-2011, 07:18 AM   #5
Rewards Points: 154
problem
I think it would be wise to call the owner of the company that installed the stove and get it sealed.
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 01:53 PM
Down draft issues - woodstove Fantastic HVAC 57 02-02-2012 03:46 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-21-2008 11:48 PM
