Old 06-29-2009, 02:23 PM   #1
Default Woodstove Backing
This may sound like a really stupid newbie question, but here goes.
I recently purchased an existing home with a beautiful 24' x 48' detached shop. The shop is extremely well built, with one exception.
It's heated by a "double barrel" (?) wood stove, just like the one we used to have in our cabin. You know, two barrels mounted longitudinally, one on top of the other with a space in between and connected with a short chimney pipe. The bottom barrel has a door mounted on what was originally the top of the barrel. The upper (heat?) barrel serves as a heat chamber and has a sealed 8" hole through the center to provide more surface area and the chimney coming out the top. The stove is mounted between 18" to 24" from the USB interior wall. In any case, they're known for cranking out the heat, or so I've been told.
There is an electrical outlet behind the stove, about 4' from the floor and directly behind the upper stove barrel. The plastic cover plate is melted! Hm....not a comforting sign.....
Years ago, I would just go down to the lumber yard, pick up a sheet of 1/4" asbestos, slap it on the wall, and problem solved. What's the procedure these days? Concrete backer board? If used, can/should I put the board on stand-off insulators to create an air space between the board and the wall?
Thank you in advance for your time and advice. It is GREATLY appreciated!
Mac
Mac44mag is offline   Reply With Quote
Old 06-29-2009, 08:02 PM   #2
old pro
I would talk to your insurance agent and local building code inspector. If there ever is a fire you are in deep doo doo if it doesn't meet code.
Old 07-01-2009, 01:00 PM   #3
I too would wonder about that outlet. I have an outlet closer than that on a pellet stove and wood stove, but because of placement and heat shields it's well outside the danger zone.
If the manufacturer is still in business I'd contact them to find the clearance for this stove, and also check your local codes to see if they override or say anything about that outlet. Also check clearance from any chimney pipes.
The folks over at hearth.com forums is a great resource for wood stoves.
Do make sure your home insurer knows about this. It may affect your rates a little but you will be covered.
dac122 is offline   Reply With Quote
More On This Topic
With rising fuel costs and the desire to heat with renewable energy sources more people are turning to wood pellet stoves. Pellet stoves burn small wood pellets which are made from sawdust that would otherwise be put into landfills. Sawdust decomposes... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be checking our chimney. Now if you have a chimney that is brick or block, you are going to want to check the mortar to make sure that none is loose or deteriorated or any missing... Read More »
We all know that children love to play. More importantly, they love to play with other children. So, to make your home the spot all of the kids in the neighborhood want to visit, consider the following ideas when planning your child's play room. Read More »
Hi! This is John on behalf of Expert Village. Now what I am going to do is show you another aspect of what you need to do is get ready for the firewood season. Here I am on top of my roof of my home and what I will do I will be taking off the cap here on... Read More »
Toilet clogged,+Sink..bathub backing up cooter Plumbing 4 03-01-2009 08:47 AM
woodstove venting ekulrenlig HVAC 3 09-17-2008 01:19 PM
woodstove JAVAMAN General Discussion 1 12-05-2007 04:31 PM
vinyl backing stuck to plywood shotdown Flooring 7 04-18-2007 09:11 PM
Mirror Backing ktyler Carpentry 1 07-03-2005 04:11 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
