-   -   Wooden Platform for A/C Compressor Unit (http://www.diychatroom.com/f17/wooden-platform-c-compressor-unit-113147/)
MrBill_DIY 08-06-2011 12:37 PM
Is it against code to install an A/C compressor unit on a wooden platform instead of a concrete slab? For space reasons, I will need to relocate my unit when it needs to be replaced, and building a 30"x30" wooden platform for it would solve the space problem.
hardwareman 08-06-2011 02:00 PM
don't know about code violations, but that is what I did. In order to have my condensing unit above my A coil I had to build a wood frame. Attached it right to the foundation of the house on one side a sank 4x4 posts into the ground for the other side. Neat and compact.
beenthere 08-06-2011 05:41 PM
Not against code here.
Master of Cold 08-07-2011 09:27 PM
You have to check your local codes. That wooden frame is a big no-no in gulf coast states. They must be anchored to a concrete pad.
